The water spout that dispenses the water from the door is leaking where the line from inside the freezer door meets it. How do I get to it. It appears the panel on the inside is glued.
Hello,
The water line inside this door is not serviceable. The only solution is to replace the whole door.
- The freezer door AP3797080
Here are the breakdown diagrams and Parts for GE GSS25XGNABB Refrigerator - AppliancePartsPros.com
[quote=Gene;798836]Hello,
Gene.[/quote]
What about the plastic spicket where the water comes out on the front? I believe it attaches to the line in the door. Can you get to it from the front?
You can remove the dispenser front cover and take it apart to see how far you can reach. The instructions are attached to the post.
How to open ice dispenser.pdf (56.0 KB)
