I purchased the part # WPL 314820. I see your response to someone else on the same part number and you refer to some tabs. My original seal does not have any tabs and was glued in place (possibly by a previous repair man). How should I attach the new felt strips, I have purchased 2 (for front and back). Is there a glue I should use? The glue on the shroud will not come off. Thanks
Yes, you should buy a high temp adhesive. Tom ApplianceEducator.com
