How do I access the pump/filter on my GE front load washer so I can clean it out?
My GE front load washer will not drain, think the pump/pump filter is clogged with latex backing from floor rugs. How do I access the pump/drain/filter to see if I can clean it out? Model wsxh208howw. Do I take the back off? Can’t see how I would take off the front or sides, etc. Thanks for any advice.
Hi.
You can access the pump area by removing two screws at the bottom of the toe panel and taking the panel off.
The filter is inside the trap #340,#341 diagr.#3.
Here are the breakdown diagrams and Replacement parts for General Electric WSXH208H0WW Washer | AppliancePartsPros.com
Good luck.
Simon.
