How can i tell
:confused: OK my dishwasher started this today. Some of control panel lights don’t all work. Also when I press start the unit won’t start. I turned off power for a few minutes and rechecked and it allowed me to do the rinse only cycle. But only once . I don’t know how to tell if it is the control panel or the control board.
Parts for Maytag MDBH955AWS Dishwasher - AppliancePartsPros.com
The usual way to troubleshoot is to check the control panel/keypad with a meter. See the tech sheet for the keypad pinouts.
If the keypad checks out OK then replace the control board. Still a bit of a crap shoot but your odds are better.
You may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
MDBH955.pdf (117.9 KB)
