How can I check my cold control
Brand:Whirlpool
Model Number:ED5VHEXVB01
Main Symptom:won’t run
What happens & when:nothing
Just join the 2 wires on the control to see what happens (not the green ground wire!).
If the refrigerator jumps back to life, replace the control.
LINK> Cold Control OEM Part
jeff sr.
An electrical test like bypassing the thermostat (as suggested by applianceaid11) or a continuity test can be done depending on what you are comfortable with. If a continuity test would be preferable, unplug the refrigerator power cord, access the thermostat wires and disconnect one of them, then test the thermostat for continuity. If it does not have continuity while it is in the on position, and the temperature is too warm, then the thermostat has failed.
