Brand:Hotpoint GE
Model Number:HTW265ASWOWW
Main Symptom:control board
What happens & when:i intsall the new conttol board i order from app.com after i istalled the washer when its on the spin mode its keep on spinning i wont stop
If your GE washer, model HTW265ASW0WW, started spinning continuously after you installed the new control board, I would first suspect that the replacement board needs to be configured or calibrated for your washer.
GE washers can behave unexpectedly when a replacement control board hasn’t been properly set up.
Here’s what I recommend checking before replacing any more parts.
1. Try a control board reset
- Unplug the washer for 2 minutes.
- Plug it back in.
- Select a normal wash cycle.
- Start the washer and see whether it operates normally.
If the washer still spins continuously, move to the next step.
2. Check the control board configuration
Some GE replacement control boards require a model-specific personality setting or setup procedure. Others come preconfigured.
The important thing is to verify whether your particular replacement board requires programming. An incorrect configuration could affect how the washer operates.
3. Verify the replacement board programming
For this model, replacement control board WH22X38438 is one board associated with the washer. GE boards in this family may require personality programming.
Expert Help
+1
Check the instructions that came with your board. If it requires programming, make sure the correct personality setting was selected and saved.
4. Check what happens when you press Pause
Start a Spin cycle with the washer empty and observe what happens.
- If pressing Pause stops the spin, the control may be failing to advance or complete the cycle.
- If the washer continues spinning despite Pause or Cancel, stop the test and unplug it. The new control or its connections need further inspection.
A couple of questions
- What is the part number of the new control board you installed? It should start with WH22X.
- Does the washer finish the spin cycle and just keep spinning, or does it spin continuously as soon as you select Spin?
- Did you program the new board after installing it?
With those answers, I can help narrow down whether this is a programming issue, a defective replacement board, or something else causing the continuous spinning.
