I have a Hotpoint clothes washer…it leaks from the bottom..first thought it was from the right side…so my husband changed the pump..put a load of clothes in this morning,it seems to be leaking again..I’ve looked underneath with a light,it may be coming from the left side. I don’t know what it could be..a simple hose or if the motot is going out..PLEASE HELP!!
Not having one in front of me right now I am going from memory and I think the water comes in on that side.
Operate with the front panel off and shine a light up there and you should be able to see the source of the leak.
Good luck, hope this helps.
