Hotpoint Oven thermostat replacement
Need to replace Thermostat but can’t get the capillary tube out of the oven. Plate that holds the burners blocks removal of tube because of length of tube.
You have to remove the top panel, the burners, the orifice spuds and the burner box which is secured with a few screws around.
Here are the breakdown diagrams and Replacement parts for GE RGB744GEV2WH | AppliancePartsPros.com
