Hotpoint Microwave Total Dead
I just moved in and there is a Hotpoint microwave model # RVM1435BD002. It is total dead. It was working by the previous tenant. The outlet is ok. I tested the fuse and is also OK. What else could have gone bad? There was a total electrical failure in the apartment because the circuit breaker was wired wrong and it burned and had to put in a new circuit breaker box.
remove the control board and see if there is any burn marks on it.
Thank You for the quick reply. Do you know which part is the control board?
Here is the part. it is located behind where you push the buttons to run the MWO…AP3418930
Thank You. I will have to check again but the last time I looked I did not notice any burns it looked good.
