Hotpoint Electric Stove (Old) Not getting very hot
Hi everyone!
We have a very old electric stove (Hotpoint). It was working fine, the burners were getting red hot, we cooked a ham, and then a few hours later it would only get warm. The burners, broil, and bake coils were all kind of hot, but they didn’t “glow”, and there is no way it would cook anything…maybe just warm it up. Does anyone know what this could be or if I could even get parts for a stove that’s probably 20 years old? Thanks so much in advance for any help!
Joanie
I cannot find any info on the given model number please check it.
Find your model number - AppliancePartsPros.com
Do the stove top elements work OK?
If not you probably have a power problem.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
