Hi all -
I’m having trouble with my electric oven and hope you can help. Here’s what I’m seeing:
- The heating elements on the stove top work.
- Broiling works.
- The oven won’t heat when I chose the bake setting. I did a continuity check on the bake element and it passed. When I try to preheat the oven to bake, the bake element does not heat up at all.
- The wire contacts that connect to the bake element at the back of the oven are not corroded or broken.
- I can’t see any other obvious indication of a problem anywhere else at the back of the oven, such as a loose connection, a burnt wire, etc.
Any thoughts on the next steps to take to troubleshoot?
JWK
