I have a Hotpoint CTF15ERR model refrigerator. I’m not sure of the amount of electricity it uses but suspect it’s a lot. It’s got the coils at the base instead of the back so at least somewhat in the ball park of not being ancient.
In the summer it will “sweat” water dropplets I think from leaky door molding.
The options are a new molding or buy an new EnergyStar fridge. What do you think would be better? Is this thing worth saving?
Here is the operators manual
http://genet.geappliances.com/DocSearch/pdf/39-6246.PDF
Take a look at Page 14
On what is better I cannot say, but if you look through this forum at the number of newer GE fridges that have fan problems and end up requiring a new control board it will be self evident.
Denman,
Thank you for the link. It seems like the moisture can be expected. My fridge has the dry/humid switch which I never noticed it. I’m in eastern Masssachusetts and the moisture on the outside only happens during hot days in the summer.
I went over my bills for the last few summers which I can compare to periods when I’m not here so only the fridge is on. They are not as bad as I thought and I’m not so sure if even a new EnergyStar refrigerator will be a worthwhile gain for energy usage.
To get a comparable box size wise and internal configuration puts me in the $450-$800 range but the quality of the boxes at Home Depot and Sears did not seem so good either in the robustness of the internal shelving or door.
I’ll probably hold off on a new one and monitor the usage some more as the droplets are a little less of a concern.
Thank you for the help.
David
