Hello, I have a General Electric Washer Dryer Combo WSM2700HCWWW.
Recently when switched off, there is a slow and steady water drip into the washer tub. I think the water inlet valve needs to be replaced. Found the part:
GE WH13X10035 Valve, Water 115V - AppliancePartsPros.com
But how do you access the water inlet valve?
I found the exploded parts diagram but disassembly is not clear.
There are youtube videos for other washers but did not find one for this model. Any help please? Many thanks!
