side by side fridge or freezer do not get cold motor and fan runs
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
A Model Number may help others help you
[COLOR=Blue]side by side fridge or freezer do not get cold motor and fan runs[/COLOR]
By motor I assume that you mean the compressor.
I also assume that both the compressor and evaporator fans are running.
Remove the evaporator coil cover in the freezer.
Check the coils for cooling/frost.
If they only have frost in one area (usually where the freon enters the coils from the compressor) then you are probably low on freon and have a leak.
