If I need to call in a professional, I will, but it seems like it should be an easy fix. I went to push the light button and the entire control panel fell IN. I can’t see a seam or screws to remove the overhang part of the hood to get the panel placed back through the hole. Any thoughts? THANKS!
Hopefully the attached installation instruction and the breakdown diagrams and Replacement parts for THERMADOR PHE36US | AppliancePartsPros.com will help.
Installation PHE.pdf (535.7 KB)
Thanks, Gene. So you must think I can do it! Joyce
At least you can try. What do you have to loose?
