somehow the drum is knock off balance seems ok except halfway thru spin
I believe i see the balancing plate but not sure how it goes:confused:
Remove the washer cabinet and check the balance ring on top of the drum and the suspension springs on the bottom.
The model number you posted does not come up. Verify and repost it please.
How to remove the washer cabinet.pdf (43.5 KB)
