On this front loading washer, the Hold to Start button is depressed and will not return to a “popped out” position. Must push very hard and work with it to even get it to start. What needs to be replaced? A switch? The entire control panel? Please provide part numbers with answer. Thanks.
sounds like the start button is broken. unfortunately the start switch is not a separate item. you must purchase the entire control board part no. 8181905. I would take it apart first, just to make sure the plastic actuator for the start is not broken
