High temp wire gauge
My range is so old that I haven’t been able find specific info about it. It is a 30 inch drop in model with controls along the left side.
I have 2 burners that are not working. Tested the burners and they are fine but when I opened up the top I discovered that the wires had come loose from the the receptacles for those 2 burners and the receptacles are in bad shape. The insulation on the wires is very degraded. I want to replace the wires as well as the receptacles. The problem is the wire that comes with new receptacles is very short so I am going to need more high temp wire to reach the controls. I know that high temp wire comes in different gauges. What gauge wire do I need to use?
Any help would be greatly appreciated.
Cheryl
[quote=ctsearch;804040]My range is so old that I haven’t been able find specific info about it. It is a 30 inch drop in model with controls along the left side.
Cheryl[/quote]
Hi Cheryl I have the same type of unit and was wondering how do u open the top of the range to get to the wiring? I need to do that to check my wiring. Any help or instructions would be appreciated. Thanks.
