Dryer makes high-pitched squeak at start of tumble then stops. Makes noise sometimes during tumble, and always just before dryer is about to stop. Could this be a belt? Dryer was given to me and I don’t have a manual for it.
Replacement parts for FRIGIDAIRE FDE436RES1 | AppliancePartsPros.com
Here is a good site with basic dryer repair help
http://www.applianceaid.com/dryers.html
Here is the Frigidaire website, where you should be able to get manuals or at least one that is a close match to your unit, if you want them. Search using FDE436
http://www.frigidaire.com/manuals
[COLOR=Blue]
Could this be a belt?[/COLOR]
I doubt it
More likely it is the rear drum support bearing.
May need cleaning and re-greasing using a high temp grease.
May also need replacing if it is worn.
Note the ball bearing (Item 5 in the Cabinet/drum section) likes to take off and hide so be careful when removing it’s retainer.
Other possibilities are the belt’s idler wheel, the front glides or the motor itself.
