Two Position Temperature Function Switch Not Working When Switched To High Heat
Have you used a multimeter to check if the switch is bad?
[QUOTE=brobriffin;901681]Have you used a multimeter to check if the switch is bad?[/QUOTE]
In order to use any multimeter, it is necessary to to begin by removing the
control panel to access the back plate. Unfortunately, I have found no one
able to tell me how to remove the control panel on this combo washer dryer.
I have removed all of the front dials…but the control panel has to be removed in order to remove the washer timer knob. But I am at a loss
trying to remove the control panel.
