Dryer wouldn’t start replaced thermal fuse started dryer ran a load dryer smells like it was over heating then cut off and won’t start now any suggestions
Parts for Roper REX4634KQ1 Dryer - AppliancePartsPros.com
When you replaced the thermal fuse did you check/clean the vent system.
This is the most common cause of the fuse blowing.
Also be sure that the vents on the outside of the house are opening.
Check your duct work to make sure it is not full of lint.
Make sure you are getting a good strong flow of air coming out of your dryer vent.
I Checked my Ducks made sure all vents were clean changed thermal fuse again dried a load of clothes then dryer stop again! What else could this be ?
See the attachment for your wiring diagram.
Unplug the unit and both wires at the heater.
Measure the heater should be 8 to 12 ohms.
Then check from each side of the element to the heater’s case.
Both should be infinite ohms.
If not the element is grounded and could run hot.
Did the unit have good air flow?
Check that the blower wheel is properly connected to the motor armature.
Sometimes they strip out. Will spin some but not enough.
Check that the blower wheel is clean.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
REX4634.pdf (209.5 KB)
