Diswasher only displays Quick clean up cycle and Energy saver dry. cannot change cycles or dry modes. 4 hour delay seems to still work. Any suggestions?
Other posts have noted similar problems with the control panel the control lock is activated. If so hold air dry down for 5 - 10 seconds to release the lock.
Control lock works fine. Tried multiple times to switch cycles but no luck.
Replacement parts for WHIRLPOOL KUDS01DLSS0 | AppliancePartsPros.com
Here is the tech sheet run the diagnostics.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208533399.pdf
Clean the connections as shown below.
Check the keyboard with a meter. If the keyboard checks out OK then the control board comes to the top of the list as the cause.
Connector Cleaning
Unplug the unit
Open it up
Clean the edge connector.
Thanks for the tech sheet, I will try to use it and your advise this weekend. Thanks once again!
You are welcome
Please let us know how it goes.
