Help with loose dryer part
Brand:samsung
Model Number:dv42h5200ep/a3
Main Symptom: loose part under the drum
Photos / video link: Found a loose part in the bottom of my dryer. It’s a round white plastic flange with hole in the middle and 2 latches on the sides. The hole is approx 1" inside diameter. Found it under the the back left side of the drum. Any idea what this is?
Maybe if I saw a picture of it I might be able to tell. Is it running and drying ok?
