a mouse chewed through my wires i need help with installation, any help would be appreciated.![]()
Your model must be fairly new as it does not come up on AppliancePartsPros.
Not sure what kind of help you need?
Have you found the tech sheet. Usually it is taped to the back of the kick plate or in that area.
This will give you the wiring diagram.
If you do not have it the Whirlpool site lists it as W10142800.
Here is a manual that may be close to your unit, but I am guessing here
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/a045b97f9e505696852574ce0049f265/$FILE/8178741.pdf
