[FONT=Arial Black][SIZE=4]Need To Install Bottom Door Short Seal. It Seems To Snap On, But Not 100% Sure. May Easily Be Able To Remove, But Not Sure If It Is As Easily Put On.[/SIZE][/FONT]
[FONT=Arial Black][SIZE=4][/SIZE][/FONT]
[FONT=Arial Black][SIZE=4]Thank You.[/SIZE][/FONT]
I have a model GSD6500. The grove on the seal slides onto (and off) the bottom of the door. It may be possible to change the seal just be removing the screws on the bottom of the door, but I found the seal easier to re-attach after removing the inside of the door. You can also clean the edges and inside of the door.
