Help! Washing machine on repeat rinse cycle
My Frigidaire 4.1 cu. Ft. High efficiency max Fill to load washer keeps giving me error code E5, then repeats the rinse cycle, multiple times. I adjust the drum when I get the error code, then it will start the rinse cycle over ever time. What’s going on? Thank you
Cali.poppy, if the model number of your appliance could be provided, it will allow the most accurate information to be presented.
