Help take grill off mocrowave
Brand:
**Model Number:**JVM1540LM5CS
Main Symptom: can’t get grill off to replace door switches.
The grill has 2 screws at the top that come out, then you should be able to remove the grill.
I have looked thoroughly and only found 1 screw. i removed it but the grill still does not budge! do i have to slide it to the left or right or pull straight off. i have looked at my installation instructions and it shows 4 screws but i simply can’t find but one screw!!
