Help replacing top burners?
I need to replace the top burners(with spark ignitor) on my stove. The old burners have two “push-on” type electrical connectors for the wires. The new burners(with spark ignitor) do not. I just see a plate with two screws in it. I’m sure I’ve ordered the right part. Do the connectors from the old burners simply get screwed onto the new burner? Is it that simple?
Steve
There are two terminals on the bottom of the burner. One for the igniter and another one for ground. What is the part number for the burner you are going to use?
I’ve ordered 4 burners, Part # AP4093856. Thanks for the reply and help. Looking at the picture, I can’t tell if the new ones have the same 2 connections. I see one, but can’t tell if it’s got the other; the longer one in the middle. Appreciate your advice.
Steve
Steve,
Looks like you are on the right track. Keep us posted.
Gene,
Thanks for the help.I’ll let you know how it goes.
Steve
Gene,
You were right. Burners arrived today and no problem installing them. They were the right parts.Thanks.
