After doing a load of dishes my Bosch dishwasher cycle countdown seems stuck at the 1 minute mark. It stayed at 1 minute for over an hour with the water still running inside. Whenever I stopped and restarted the diswasher it went back to the 1 minute time. Please help me as Thanksgiving is only a couple of days away.
thanks
Is the water as hot as usual when you open it at the end? If not, I would start by checking the circuitboard for a burnt out solder connection. This seems to be the most common problem people post with your symptoms. Board is inside control module:
Fascia panel replacement parts for BOSCH SHU5306 UC/12 (FD 8003-) | AppliancePartsPros.com
Also read this:
Bosch Dishwasher Control Module (266746)**|**ApplianceJournal.com
