Help! Oven Thinks Door Is Open?
[FONT=Arial]My oven thinks the door is open. Because of this the light will not go off and the convection fan will not run. When the oven is not broken and the door is opened, the convection fan turns off while the door is opened and the light comes on while the door is opened. Since the oven thinks the door is open the light will NOT turn off and the bulb has burned out. I really like the convection fan capability on my range. Please help!! Would this be part #AP3008355 the switch on the door or a sensor of some sort?
Any idea would be soooo appreciated!!!
Cindy :)[/FONT]
I hope someone can help with this. I have no clue what to do.
Here are the parts
Replacement parts for GR450LXL models | AppliancePartsPros.com
See the attachment for the wiring diagram.
Yes it could be the door switch you listed but also may be the control board.
The switch feeds the control board which then controls the lights etc.
I would check the switch with a meter to see if it is opening/closing.
Probably easiest to do this at the control board.
Have you tried unplugging/removing power from the unit for a couple minutes to see if it will reset?
GR450.pdf (318.4 KB)
