Help on installing door gasket to drum on front load washer
just replaced the o-ring on the outer drum. put everything back together but having a hard time attaching the boot from the door to the inner drum. are there directions out there that i can download? There is a large spring that is used to hold it in place. what is the trick ongetting this back together?
Don
The instructions attached to this post are not for this model exactly, but they should help you.
Reinstalling or replacing the bellows.pdf (219.2 KB)
