Well Here We Are After Thanksgiving Dinner First Load The Kenmore Just Hums ,there Is About 2.5 " Of Water In The Thing But Will Not Run,anyone Out There To Assist Before We Consider Shopping For A New Unit ? P.s.,the Hum Stops After A Minute Or Two.does This Mean Overload Condition Of Some Type ?
Thanks In Advance,
Bailing In Philly…
If it hums and then stops it is kicking out on overload. Check the sump for any debris in chopper and if its clear then looks like a motor/pump assembly replacement. 363.14039001
