HELP! Dryer has no heat
Dryer will not heat - Whirlpool model LGR6848AZ2. Yesterday, the dryer wouldn’t tumble. I changed the belt & it fixed the problem…temporarily. I did 4 loads of laundry just fine. Now the dryer tumbles but has no heat. I tested the outlet w/ multimeter, it’s fine. What did I break? Any help would be greatly appreciated! Thanks!
I’ve attached a tech sheet…(Gas Burners)read it and follow instructions. It will fix your issues.Pages 12-14 if this all checks out then check your thermal fuse and thermostats behind the back panel…they should all read
zero ohms.This info is on the tech sheet attachment page 6
If you get stuck let me know.
Good Luck
K
Tech Sheet - 8545908[1].pdf (411.3 KB)
i couldnt get the gas burner sheet to upload so sent this instead.
K
Gas Dryer Not Heating Properly.pdf (28.1 KB)
How To Check Dryer Parts For Continuity
see administrators post for this info
