Over the last few months groups of buttons on the keypad started failing. Now none of them work. The Stove has been very lightly used, and there is no physical wear on the keypad itself. I suspect it is the control board instead of the keypad, but I am not an expert. Could someone experienced make a better guess than me?
I am assuming that you have unplugged the unit for 5 minutes or so to see if it will reset.
The usual way to troubleshoot this is to check the keypad keys with a meter, see the tech sheet.
If all the keys check out OK then replace the control board. Still a bit of a crap shoot but your odds are better.
You may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Always remove power from the machine otherwise you could blow your meter.
Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
There is a good STICKY at the start of this forum about it’s use. JES8750.pdf (1.3 MB)
