First, thanks in advance to all for helping out! I am new and found this site due to my current problem.
The fridge compartment was not cooling. I was able to relatively quickly confirm that the evaporator thermostat was failed open. I began defrosting the coils with a hairdryer, but opted to let the heater finish the task after I had bypassed the faulty thermostat - the beginning of my problem. I went back after about 5 minutes to check on the defrosting progress to find that the towel I had placed under the coils earlier to help with all the water (and forgot about) was actually touching the heater and beginning to burn.
The problem: I have an area on the interior panel that suffered heat damage: melting and cracks. I removed the brittle cracks and am left with an area about a 1" x 2" where the foam is exposed.
Do I need to repair it?
How do I repair?
Is the foam flammable? I ask because it is directly across from the vertical part of the heater tube about 2" separated.
I do not know what to do. I do not want to use the new heater assembly until I am confident that I will not do more damage. I say this because the damaged area is about 3" above where the towel was and not real easy to see unless you are looking directly at that area. A part of me wonders if the defrost heater did this damage over its six years of use, and I simply did not notice it until after the towel incident, which caused me to freak out and look at everything very closely. If there is a reasonable chance that the heater did the damage, I certainly do not want to run the new one and have a fire hazard.
Sorry for the long post…
