Help Brunette on my Dryer
Now that I have your attention.
Gas cloths Dryer help.
I have a Frigidaire gas dryer model GLGR331AS3. It is taking up to two hours to fully dry a load of laundry. The clothes are hot but just not drying properly. The igniter comes on and glows orange, the gas SOV clicks on and injects (propane), and the flame burns orange. I know the fame should be blue. The flame seems to be week however I never monitored the flame while dryer was operating correctly.
Key indicator:
I can change the three position {Low/Medium/High** fabric selector switch setting without a change in flame intensity.
I have also checked the following:
1. Completely removed exhaust hose from dryer end checked for pluggage.
2. Checked duct work rear of dryer for pluggage.
3. Removed front of dryer and cleaned out blower fan and vacuumed out bottom of dryer.
4. Checked exhaust outside of home to ensure good flow and no restrictions.
5. With vent line unhooked: I ran the dryer on high heat and 70 minutes with a load of jeans. Jeans where still damp after 70 minutes.
Airflow problem are usually caused by restrictions, leaks or short unrestricted vents resulting in longer drying times and hotter dryer surfaces.
The full description on the airflow and its problems is attached to the reply.
Dryer airflow.pdf (284.8 KB)
Dryer airflow problems.pdf (135.5 KB)
