Heating Parts
Heating parts such as replacement gas valves, ignitors, and ignition modules can be found here - heating parts.
Can you get parts for heating for cars on that site? Just wondering…
[QUOTE=Admin / APP Team;13839]Heating parts such as replacement gas valves, ignitors, and ignition modules can be found here - heating parts.[/QUOTE]
need replacement or mng. part for mod.#fav18ej2a1 unit it has bad sel. switch the mng.# is 5308017262 switch is rated 6amp 1/4hp 120/240 and 21amp 120/240 with total rating of 25fla 90lra 240 volt
Need replacement for gas valve. Please help!
Hi..in my case e clock started blinking and I noticed none of the burners were getting hot and the display stopped working unless I had one of the burner switches on. So now none of the burners heat at all, the oven doesn’t heat at all and the display only displays if I have a burner switch turned on??
