All the heating elements went out on the Oven. At first, just thought it was the oven element (baking) but when I turned on the range top elements - none them work now either. This is a ceramic top stove with the elemements underneath…
Iv’e pulled the oven out and was going to take a look tonight but really have no clue what’s going on here. Fuse? thermostat?
I cannot find any info on the given model number, please check it.
Model Number Locator
Unless the unit uses digital control of the stove top elements then odds are good that it is a power problem since the oven control and the stove top controls are separate.
I would check the power first.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
