Heating Element Issues Samsung DV42H5200EP/A3
My Samsung dryer continues to experience heating element failure. Despite replacing the heating element multiple times, it repeatedly burns out. The dryer otherwise functions normally. I am trying to determine the underlying cause of the recurring heating element failure rather than continuing to replace the component.
Furthermore, I was given this dryer for free in 2021. I would like to keep the dryer running til i physically can not replace something, or unless the motor or the pcb runs out. This would be the 7th or 8th heating element in the past year or so.
Lastly, what is the wiring on the heating element itself? I’ve seen a couple photos and theres differences between the two photos with how the element is wired. I think this could be a key issue.
Brand: Samsung
Model Number: DV42H5200EP/A3
Main Symptom: Heating Element Failure
What happens & when: Once the element is replaced, the heating element will dryer for two to three loads then it will short out and/or will go out. Upon investigating a couple of fuses will be blown and I’ll have to rinse and repeat the cycle.
Error Code (if any): No error codes are being produced on the dryer.
Parts or tests already tried: I’ve replaced all of the main fuses and the heating element several times.
