Heating element doesn't shut down
This dryer works well in all functions except - the heating element does not turn off in the ‘cool down’ section of the timer. It stays on full until the complete cycle is finished and the dryer shuts off.
Replacement parts for WHIRLPOOL LER3624EQ0 | AppliancePartsPros.com
Here is the wiring diagram for your unit, see the attachment
Just did one with the same problem just a different unit, see the following.
http://forum.appliancepartspros.com/dryer-repair/166188-mike-s.html
In your case the timer contacts would be timer switch 2.
Wiring Sheet - 3406688 dryer.pdf (237.0 KB)
