Brand: Kitchen Aid Model Number: KDTE204DSSO Main Symptom: Won’t heat/dry dishes What happens & when: Won’t Dry Dishes, or heat water. I’ve replaced the Thermostat, heater core and control module. Tested all for continuity and still no result. Cycle runs but no heat. Tested for continuity both before and after replacing the parts.
Error Code (if any): None
Parts or tests already tried: Heater Core, Thermostat & Control Board
Have you ever run the diagnostic mode to check for errors and run the test cycle?
The test cycle in diagnostic mode ignores some things that may prevent the heater from coming on in normal operation, it also resets the unit so that the 1st 3 regular cycles after the diagnostic test cycle are used as calibration cycles. You may have fixed the issue, but the appliance doesn’t know that because it never rechecks those systems unless diag mode has been run.
The heater is run at the end of the test cycle, so once it has completed the cycle you should be able to open the door and put your hand near the heater (but don’t touch it) to see if it came on.
Here’s the tech sheet for this model if you don’t have one, this should help you get into diag to check codes and run that test cycle:
If the heater seems to be working in diagnostics mode but the issue of not heating continues in normal operation or comes back after those 3 calibration cycles, you likely have a bad optical wash indicator AP6023867. That is what senses whether or not the unit is heating.
Again thank you for the information. I’m pretty handy, but not a board level electronic guy. So this is what I did, I hit the start button, followed by the first three buttons from the left side of the panel, of which I hit 1,2,3, three times. The whole panel lit up from right to left, and then I closed the door. It went through a series of noises/steps and then stopped, I believe. I then placed a dish tab, some dishes and depressed the normal button, which lit up the heat button, and then pressed start, and closed door. As it went through the cycle I did notice the heat element worked, which was a big plus. However some water, slight at best seeps out from the front panel, when I opened it there was a lot of suds in the bottom of the unit. Any thoughts? All fittings that I came in contact with are all firmly sealed. The water that did come out seemed like it had a little discolor to it.
Actually, sudsing can cause something like this. Too much suds blocks the view of the OWI I talked about earlier and keeps it from reading properly. Start a normal cycle with the washer empty and wait for it to perform the initial fill, once that’s done open the door and add a couple cups of white vinegar or a dishwasher cleaner like Affresh AP6331158 to the tub, close the door, resume the cycle and just let it run through. That’ll clean out the system of any detergent residue that may be causing suds.
