Heater element connection
i hve a whirlpool quiet partner 2 model DU1145XTPB6 purchased in 05’. had the clean light blink 7 times. did the reset on control panel. cleared it, light came on again after it was trying to wash. just had plumbers re-do pipes in house, they took DW out and put back in, now i hve found 2 wires under tub, 1 from heater element (orange)and other from main wiring harness(white/red stripe) disconnected. they were attached to this little button cell type part with 2 prongs. part # could either be cs-7sa-80 or i think 3371518 kind of hard to read so small. was wondering if those 2 wires had to be connected correctly, or could go to either side of that part. any help would be appreciated. marc… looks like the part is the thermostat. does it made what side either wire goes to ? looks like it don’t matter.
Is this the part? Click on the picture for better views.
AP6010246
It does not matter which wire goes to which connector.
The thermostat should be 0 ohms at room temperature.
That was the part. Finally figured out what the name was. Hooked those 2 wires up, and now it works just the way it did before. Thx for the help !
