Heater element bad?
My Kenmore dishwasher will no longer heat the wash water and the heating element doesn’t dry the dishes after a wash.
I have checked the connections on the element and thermistor and they are all good. I do have a multimeter but I have not measured the Ohms on either piece and even if I did, I don’t know what the resistance should be since I can’t find a reference for it anywhere.
Does this sound like a bad element(Hopefully…$26:) )or could there be something else I should look at?
Thanks for the assistance.
Here are the parts
Replacement parts for 665.16533202 models | AppliancePartsPros.com
Here is the tech sheet with the info you require
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
