Heat from dryer won't work
The dryer won’t produce heat anymore therfore doesn’t dry my clothes. What should I do?
With the information we have so far, the possibilities are almost endless. Let’s try to narrow it down a little.
Is the igniter glowing?
Your dryer should have a little plastic plug on the lower left of the front panel. Remove it, it just pops out. Turn the dryer to timed dry, set on high heat, start it, and watch through the little opening. Does the igniter glow orange?
