Hello I have a problem with my washer, the control panel comes on i can setup the machine but once i press start it locks the door and nothing happens. I found the Tech Sheet and got to read the codes so i found error code E22 and E54. I also tried to reset the codes then start back the machine to see what happens and it was the same thing again. Read the codes again and now it only shows E54 code. Can anyone please help me with this and what should I do.
Your Help with Greatly Appreciated.
Thank you
