I have a dyrer from my son whom works at a retirement home he gave me from there , it came with a bag of brand new parts which i put onto dryer because ; the other day i needed a work shirt that was drying and i opened the dryer while it was spinning (electric dyrer btw) and shut it and tryed to restart it but no go ??? So i took front panel and door off found a wire that was / seemed burnt and not really a connection so i fixed the wire i think it was on the thermal hickie so while i had it apart cleaned it replaced all the eletrical gadgets inside the dryer put on new tumbler wheels new belt etc. from the bag of new parts. Put it back together still no go replaced door button as i had a new one , still wont start so i tryed having my son hold the door switch in and push the timer in while i spun barrel by hand and dryer would kick in and stay running while holding door switch in but the barrel was trying to spin but barely moving , so it came with a new timer so i replaced it still same dryer will barely move and will not kick into or on only with hand starting it motor is spinning by the way does it to kick itself into higher gear or is my motor shot ? Thank You for your help. Mike
Sounds like the motor has gone bad.
- The motor AP6006386
Here are the breakdown diagrams and Replacement parts for AMANA LES33AW | AppliancePartsPros.com
