Hardwick
select buttons for Broil and Oven not working. When select broil or Oven buttons and select temperature control it goes β€œON” and within minute it
goes OFF.
Is there any fault on these buttons or there is some other problem?
:slight_smile: :slight_smile:
Hi Anwar,
Looks like the problem is a bad control board. Unfortunately this part is no longer available. Probably it’s a time for a new range.
Here are the breakdown diagrams and Replacement parts for HARDWICK CPG9841A689DQ RANGE- S/C F/S GAS | AppliancePartsPros.com
