Having problem getting oven started. Depressing oven on the keypad doesn’t do anything and approx half of the items on the keypad doesnt functions. Nothing happens when the keys are depressed. Have replaced part MAKE=WPL P/N = 740099154 DESC = CNTRELEC. HELP -
Thanks…
Replacement parts for JENN-AIR JGR8875QDS RANGE- S/C F/S GAS | AppliancePartsPros.com
The part number you listed does not cross reference to an AppliancePartsPros number so I am assuming you replaced Item 2 in Section 3.
So it looks like the control panel/keypad (Item 1 in Section 3) is the cause.
It shows the pin outs for the keypad/ribbon cable. You will notice that each circuit track is for a number of keys.
You could check the keypad using a meter just to confirm that is is shot.
Could also try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
JGR8875.pdf (373.6 KB)
