Haier Wine Cooler model BC112G
Brand:Haier
Model Number:BC112G
Main Symptom: Getting too cold ( below 32F)
What happens & when: temperature is set to 65F but it keeps cooling so is not shutting off the compressor
Error Code (if any): LL was on the screen initially
Parts or tests already tried: removed temperature probe and measured 2kohm at 73F and 5.5 kohm at 32F in an ice water bath. The sensor part number is RF 6250-01 which shows as no longer available but since I do not have the temperature vs resistance chart for the sensor, I am not sure if it is correct, although the digital readout of the temperature is showing what appears to be what the actual temperature is inside the cooler. So not sure if the temperature sensor is the issue or if it’s the control board that the temperature sensor plugs into that is the issue. It seems the control board show also as not available
Based on the readings that you are getting for the thermistor, this would likely be a faulty thermistor. The resistance at 73 degrees would be a little low and the reading at 32 degrees is way off.
What should the resistance reading be at 73F and at 32F? Is there a temperature resistance chart available ? Since the thermistor is no longer available, can you suggest an alternate thermistor with a similar temperature/resistance response. Thanks again for the help, I really appreciate it!!
We do not have the exact readings but based on the most common thermistors, the resistance at 77 degrees should be 5K ohms and would be around 16K at 32 degrees. That may be off but still you are getting a low resistance value at 32 degrees.
Don’t know if any of this helps.Looks like not much available
Haier BC112G Wine Cooler Service Manual.pdf (505.1 KB)
SB-RF-0007.pdf (181.6 KB)
for this!
Thanks very much, I was thinking that it should be around 16K in the ice bath so certainly does look like the thermistor is malfunctioning. Thanks again for all the help. I’ll see if I can find an aftermarket thermistor with that kind of response and give it a try.
This may help:
Thermistor Values Cheat Sheet.pdf (3.9 MB)
Thanks for all of the information. I ended up getting the cooler to function again without replacing any parts. I had an assortment of resistors so unplugged the Thermistor and connected a 2 kohm resistor across the board pins and the digital readout showed 77F. I did the same with a 7 kohm resistor and the readout was 27F, 3 kohm= 61, 5kohm= 41, 13 kohm =LL. When I connected the 5, 7 & 13 kohm resistors the compressor did not start which before with the thermistor connected and immersed in ice water and a readout of 41, the compressor kept running. So, I am thinking that my issue was a stuck relay and with all the jostling around I was doing during disassembly including removing the board near the compressor with the start relay, it must have became unstuck. Figured I would shared my resistor data in case anyone else has issues with a similar unit, but looking at the readout readings I was getting for the various resistors it looks like they are using a 2 kohm NTC thermistor if I’m understanding correctly on how they are specified at 77F (25C). Thanks again for the help.
