Brand:GE
Model Number:Gud27essm1ww
Main Symptom:
What happens & when: received replacement motor but it only has 1 harness plug instead of 2 Was told this is the correct replacement motor
Is there a replacement harness or jumper to fix this?
Brand:GE
Main Symptom:
Based on the model number provided the correct motor for the washer is WH49X27319 Motor And Pulley Assembly | Genuine Ge OEM In Stock
And the motor for the dryer is:
WE49X27320 Kit Motor Drive And Pulley 27 Nv | Genuine Ge OEM In Stock
